As the title suggest, I tried to pick up an OBJ file export from the “File” node from within the geometry node (not the DOP). I tried this on two systems and with both I had the same luck. Insta-crash.
I tried the following workarounds:
- Exporting the mesh as BGEO (it works), load it in a new scene and re-export as OBJ
- Assembling everything into a single object and export it as OBJ
- Triangulating & Remeshing the final geometry
All efforts met the insta-crash.
Other geometry I created through manipulation (bigger in size than the Voronoi object), was exported successfully.
Any ideas?
Thank you in advance!
