Hi All,
I'm having a little issue with the wire object and customize where the collision should happen along the curve.
I want the “roots” of a groom to be excluded from collision detection and therefore I'm assigning a value of 1 for the first 2 verts.
It happens to exclude indeed the collisions only for the first edge but the weird thing is that is killing along the whole line/curve the self collisions. Super easy to reproduce as I did also a test with only 2 lines (see image). Same result.
Anyone that had the same issue and would like to share how can I solve that. It's a known bug?
Many thanks in advance.
Cheers
Wire Object - selfcollision disabled when setting some value for the nocollide parameter.
1460 3 0- MicheleA
- 8 posts
- MicheleA
- 8 posts
- derrick
- スタッフ
- 329 posts
- MicheleA
- 8 posts
