I recently did this tutorial by Entagma http://www.entagma.com/quicktip-rayleigh-taylor-instability-season-3-is-here/ [www.entagma.com] (It is a thin flip fluid sim that swirls around, and I cached out the points)
Everything is working great, but I want to put a picture behind it on frame one, attribute transfer color to the particles, store the Cd and then remove the image and see what patterns this makes.
I made a vector attribute called Ctrans to store the color and Pswitch to toggle when to fill Ctrans. I then made a point wrangle with this code:
if(@Pswitch==1){
v@Ctrans.x = v@Cd.r;
v@Ctrans.y = v@Cd.g;
v@Ctrans.z = v@Cd.b;
@Pswitch=0;
@Cd = @Ctrans;
It acts as if @Pswitch is always 1, even when the geometry spread sheet says it is 0.
Thank you for you time, any tip helps!
Vex ignoring an "if" statement (?)
2890 5 1- animationalex
- 53 posts
- neil_math_comp
- 1743 posts
Hi! What version and build number of Houdini are you using? Is Pswitch 0 in the input geometry, or just in the output geometry? If you're using 16.5, does this still happen in 17.0? If it's happening in 17.0, could you submit a bug report?
- animationalex
- 53 posts
ndickson
When I created the attribute with “attribute create” in the node above it, it is set to 1. I am using 16.5, I will try it in 17 and submit a bug report if it is still happening. Thank you.
- neil_math_comp
- 1743 posts
animationalexOh, sorry, I don't understand. If the attribute is 1 in the input, VEX should be acting as if it's 1, unless you've set it to 0 somewhere before the if statement. If it's 1 in the input, the VEX code you posted sets it to 0, so it'd be 0 in the output either way.
- animationalex
- 53 posts
ndicksonanimationalexOh, sorry, I don't understand. If the attribute is 1 in the input, VEX should be acting as if it's 1, unless you've set it to 0 somewhere before the if statement. If it's 1 in the input, the VEX code you posted sets it to 0, so it'd be 0 in the output either way.
What I was hoping this code would do is that when Houdini evaluates the node, it see the switch is at 1, runs the code, then turns off the switch so it will stop changing the values it is assigning when it changes frame number and evaluates again.
- neil_math_comp
- 1743 posts
animationalexSOPs always read from their input and write to their output. They don't read from their previous output, (except sometimes for performance optimization, but it's required to be as if it read from its input).
If you want changes over time, you'll either need to change the condition to be something explicitly time dependent, like
if (@Time == 0)
, or you'll need to use a Solver SOP, which uses DOPs internally to be able to operate on geometry of previous frames. It doesn't sound like you'll probably need either of those in this case, since you can probably just reorganize your network with the data flow of SOPs in mind, though I don't know enough about what you're trying to do to say for certain.Hopefully that helps clarify things a bit.
