Overlapping Curves Offset with PointCloud?
1460 4 0- ProceduralFrankie
- 76 posts
Hello everyone,
I have banging my head about the following set up: I have many curves overlapping each others and need to offset one of the two at the intersecting points like in the attached. I have tried both with pcfind and pcopen and succeded to find an array of points that represent the intersection areas. The problem now is how do i chose only one of the points in the ‘group’ and only offset that one in the y axes so to have one curve over the other?
Any other easier/faster method would be much appretiated. I also tried to get the intersection points from intersection analysys SOP but it deletes the original geometry and curvesect SOP only seems to work between 2 curves.
Thank you very much
Francesco
Thank you very much
Francesco
Edited by ProceduralFrankie - 2018年12月23日 09:43:24
- tamte
- 8597 posts
either of those method could work, the idea is to find only closest point from other curves and move only if the @primnum of found curve is smaller (or larger) than current point's curve, so that only one is moved given the mutual match
however since you really want closest distance to the curve, the best and easiest metchod would probably be using
xyzdist()
and again only find the nearest curve other than current and move points only if that curve's @primnum is smaller (or larger) than current @primnum
xyzdist()
float radius = chf("radius"); float height = chf("height"); int pid; vector puv; float dist = xyzdist(0, "!" + itoa(@primnum), @P, pid, puv, radius); if (pid > @primnum) { @P.y += height * chramp("falloff", fit(dist, 0, radius, 0, 1)); }
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
- ProceduralFrankie
- 76 posts
- tamte
- 8597 posts
ProceduralFrankie
I don't quite get what is the “!” doing it the xyzdist function?
! means not in the group fields
used xyzdist function is of this form:
float xyzdist(<geometry>geometry, string primgroup, vector origin, int &prim, vector &uv, float maxdist)
so you can see that “!” is in the primgroup argument
@primnum for each point will return the prim number that that point belongs to
so if you resolve the whole
you will get!0 for all points of prim(curve) 0
!1 for all points of prim(curve) 1
in other words you are telling xyzdist() function to find closest distance to all the curves that are not the curve that the current point belongs to
Edited by tamte - 2018年12月23日 12:13:29
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
- ProceduralFrankie
- 76 posts
I got it!I use it quite often for group selections and alike, but never saw it used in function.
I have few more doubts i would like to ask your help for, if you don't mind.
Firstly, after animating the curves with a carve, i noticed that sometimes is not the curve that is reaching the other that has “already passed” to go over it(which is what i would expect), but the other way around.
Secondly, what if a third line happens to be intersecting in a point where two are already overlapped?How could that be offset to be on top of the previous two?
Thank you
Francesco
Thank you
Francesco
Edited by ProceduralFrankie - 2018年12月23日 13:16:45
