GroupSOP.. if you select NumberENABLE and “Group by Expression”.. then I write an expression which contains numbers.. if i middle click on that number.. i cant use non integer number on the middleclick values bar, just “1” “10” 100" appears…. would be usefull to have the full float there.
h8.1.708 Linux
cheers
RFE or BUG? : GroupSOP middle mouse click
3377 4 0- VisualCortexLab
- 509 posts
- Ondrej
- スタッフ
- 1072 posts
- VisualCortexLab
- 509 posts
True … but the expression can contains float numbers i guess… like in my case.. the expression was “$CR <= 0.2” … in that case it would be usefull to use the middle click function… imho.
cheers
cheers
JcN
VisualCortexLab Ltd :: www.visualcortexlab.com
- jesta
- 311 posts
- Ondrej
- スタッフ
- 1072 posts
