Solaris - Packed primitives to Point Instancer issues
2558 6 4- Tanto
- 398 posts
Hello, Solaris newbie here, I'm trying to convert packed primitives to a USD point instancer to ultimately export to Clarisse. Everything works fine, except I somehow lose the Cd attribute on my points to create variation among instances, although the Cd attribute packed inside the instances work fine and are usable in Clarisse. Any ideas?
- Tanto
- 398 posts
- dansidi
- 59 posts
- OdFotan
- 192 posts
- jsmack
- 7803 posts
- OdFotan
- 192 posts
jsmack
This is working for me with Karma and displayColor on point instances.
Thank you. I see that your file works.
I think we're not supposed to see the color in the OpenGL viewport then.
Also I do not convert Cd to displayColor manually, will test that out also.
What's also interesting: I had to install a daily build of Houdini in order to get the mtlx nodes you used. It seems SideFX is adding nodes as we speak! Great.
- OdFotan
- 192 posts
