Custom Curve HDA
   2028   5   1
I want to make a custom curve HDA that need edit/insert point in it as Curve SOP.
The “Curve Point Translator” handle can edit curve point. But this handle can't insert point.
I tested the “curve” viewer state.
viewer.setCurrentState('curve',False,hou.stateGenerateMode.Enter)
Saddly, can't enter in edit mode.
File “<console>”, line 1, in <module>
File “C:/PROGRA~1/SIDEEF~1/HOUDIN~1.359/houdini/python2.7libs\hou.py”, line 56949, in setCurrentState
return _hou.SceneViewer_setCurrentState(*args, **kwargs)
OperationFailed: The attempted operation failed.
Failed setting state named “curve”.
Anyone could give me some help?
スタッフ
Please post your python state and a test scene so I can have a look.
mabelzile
I have no custom python state. I just set ‘curve’ state for current HDA.
スタッフ
In this case, Houdini expects your custom node to have the same name as the curve state.
mabelzile
This means the operation is impossable? My HDA can not have the same name as inner Curve sop because definition collision.
スタッフ
jerry7
mabelzile
If you can't rename your HDA to match the curve state name then a python state might be what you need.
