Avoid sceneViewer.selectGeometry() break running ?
   2185   2   0
In the following code. We can't get “finish” output if the current selection is break ( Change to other tool ).
import toolutils
view = toolutils.sceneViewer()
view.selectGeometry() # if the selectint are break, we can't get "finish" result.
print "finish"
I need do some clear work for user break the selection. How to catch this?
Edited by jerry7 - 2020年2月12日 10:06:57
スタッフ
The hou.SceneViewer.selectGeometry() call should be raising an hou.OperationInterrupted exception when it is interrupted, so you can do something like the following.
try:
    print "finish"
except hou.OperationInterrupted:
    print "interrupted"
Hi Ondrej, It is just my need. Thank you very much!
