The new version of rpyc is much more stable and easy to use than the builtin version (3.0.7)
Please consider to update it.
If I use PDG node to start a ThreadedServer on a new process(each work item holds a connection), and the server will be shut down. I've changed some code of the rpyc 4.1.4 to make it work with Houdini, and it works fine now.
Ref for rpyc version to 4.1.4
513 0 0- EricSheng
- 159 posts
