I've been trying to generate an autorig, but whenever I hit create it spits out an error. I am usuing H17.5.391. I have tried embedded file as well as saving HDA to disk. I would like to know what is going on. I hope someone can help soon, thank you.
ERROR MESSAGE:
File “C:/PROGRA~1/SIDEEF~1/Houdini 17.5.391/houdini/python2.7libs\autorigs\ui\uiMenuBar.py”, line 230, in newAutorig
self.newAutorigFromSettings(create_values)
File “C:/PROGRA~1/SIDEEF~1/Houdini 17.5.391/houdini/python2.7libs\autorigs\ui\uiMenuBar.py”, line 234, in newAutorigFromSettings
self.charactertabs.newCharacter(create_values)
File “C:/PROGRA~1/SIDEEF~1/Houdini 17.5.391/houdini/python2.7libs\autorigs\ui\uiCharacterTabs.py”, line 95, in newCharacter
autorigs_asset.buildInitialAsset()
File “C:/PROGRA~1/SIDEEF~1/Houdini 17.5.391/houdini/python2.7libs\autorigs\asset\autoRigsAsset.py”, line 289, in buildInitialAsset
ignore_external_references = True)
File “C:/PROGRA~1/SIDEEF~1/Houdini 17.5.391/houdini/python2.7libs\houpythonportion\ui.py”, line 850, in decorator
return func(*args, **kwargs)
File “C:/PROGRA~1/SIDEEF~1/Houdini 17.5.391/houdini/python2.7libs\hou.py”, line 9990, in createDigitalAsset
return _hou.Node_createDigitalAsset(*args, **kwargs)
hou.ObjectWasDeleted: Attempt to access an object that no longer exists in Houdini.
