Ok i feel like there is a simple solution to this, but i can't seem to find it.
All i want is to import a model and procedurally select one edge from it. Not edge loop, just one edge ... and it doesn't matter which one. Then create a group out of it.
Tried just putting "p0-1" into a group, but for some models, the points are not next to each other, so it's not working. And i don't want to use the sort node and mess up the order of the points, because it may cause problems for my workflow ...
Select one edge from a model [SOLVED]
683 2 0- SnowballWar
- 39 posts
- tamte
- 8549 posts
- SnowballWar
- 39 posts
