I'm trying something for sequence shots.
What I want to do is set a variable that can be picked up downstream but only in that branch.
So simplest imaginary version of it:
- Setting @scale=2 in an attribute wrangle (or something).
- Use @scale as expression/token for a cube/box's scale value.
- Being able to have multiple of these in their own branches, with their own values.
Maybe this is super obvious but cant get my head around it.
"Edit context option" only works upstream, so not an option. "store parameter values" does seem to do what i want either. Attribute wrangle does nothing. I also don't want to link to a particular node to set value.
Create variable to be picked up downstream? [SOLVED]
1514 1 0-
- AndreasWeidman
- 129 posts
- オフライン
- AndreasWeidman
- 129 posts
- オフライン
