python LOP issue
   1475   1   0
Hi;
I'm having an odd experience in Solaris, and I'm not sure if it's a bug or something I'm doing wrong:
I have a python LOP that does some maths and sets the Exposure parameter of my render camera. There's nothing too tricky about it beyond this. However, I notice that when I make changes to my scene graph upstream of this node, I cannot see those changes unless I disable and re-enable the python LOP.
A specific example is: I have a Material Library upstream of the python LOP. Downstream of the python LOP, I have a sopCreate that makes a volume, and I assign a shader from the upstream library to the volume. If I change shader params on the shader in the library, I don't see changes unless I disable/reenable the python node.
Anyone else experience this?
スタッフ
Yep, that definitely sounds like a bug or you doing something wrong
Hip file?
