Missing input node
   1894   2   1
Im deeply sorry for this noob question but awkwardly i couldn't find any solution.
why my cylinder generator doesn't have any input node?
https://www.youtube.com/watch?v=K2M3Fa59HCI [www.youtube.com] im trying to follow this tutorial but i have failed
I worked VFXs on other apps but Houdini is new for me.
you may need to switch the version of Labs Cylinder Generator
follow this [www.sidefx.com] to see how to enable menu definition dropdown where you csn switch it
I ended up in the same spot, I was following a tutorial, where the instructor add a line node and then followed by a Labs Cylinder node. At first, I didn't have an input node on the cylinder, and I ended up here in this forum and fixed that, but now I don't see a cylinder geometry at all. Need help with that. I have attached an image.
Houdini_Cylinger not visible.JPG (512.4 KB)
