vector pos = point(0, "P", 6);
int npts = nearpoints(0, pos, 1.5);
printf("%s\n", npts);
foreach(int npt; npts){
if(npt == 6 || npt == 1){
removevalue(npts, npt);
===========result:
{6, 1, 5, 7, 11}
{1, 5, 7, 11}
Why point 1 cannot be removed
why Some point number cannot be removed from the array
385 4 1- luotexia2310
- 3 posts
- animatrix_
- 4520 posts
You shouldn't modify the array you are looping over when using foreach loop. You don't have to loop over the elements like that to remove values. Just do like this:
Or loop over the elements to remove:
removevalue ( npts, 6 ); removevalue ( npts, 1 );
int elements [ ] = { 6, 1 }; foreach ( int element; elements ) removevalue ( npts, element );
Edited by animatrix_ - 2024年4月12日 11:24:47
- Tanto
- 396 posts
- luotexia2310
- 3 posts
动画师_
You shouldn't modify the array you are looping over when using foreach loop. You don't have to loop over the elements like that to remove values. Just do like this:removevalue ( npts, 6 ); removevalue ( npts, 1 );
Or loop over the elements to remove:int elements [ ] = { 6, 1 }; foreach ( int element; elements ) removevalue ( npts, element );
I understand, thank you very much!
- luotexia2310
- 3 posts
