Local Particle Rotation (VOPS Please)
   1272   3   0
-I am looking for an easy way to rotate a particle locally in VOPS. In Softimage there is a compound called "Transform Local" that allows all local transforms.
- Softimage also has a "Rotate Vector" node that allows you to rotate a particle around a vector, which really just moves the particle to the rotated position but keeps the particles orientation. I am also wondering if Houdini has a simple solution for that.
thanks
and in qLib set's of plugs you have also nice examples
Conservation of Momentum
And this maybe.
オンライン
jamination
it really depends on how you are representing rotation on particle, whether, v@v and v@up, v@N and v@up, p@orient, or 3@transform
in case of quaternion p@orient you can use Quaternion Multiply VOP, qmultiply() in VEX to rotate quaternion B by quaternion A, so B is the local one
in case of 3@transform, you can directly use Multiply VOP, * in VEX, to rotate matrix A by matrix B, in which case A is the local one
jamination
again, just multiply your vector by matrix using Multiply VOP or by quaternion using Rotate By Quaternion VOP ( qrotate() in VEX )
