bgeo animation
   3644   2   1
Hey eveyrone! Quick question on imported bgeo animation. I managed to import an animated character and used the timeblend node to hold the last frame of the animation for x amount of frames. I would like to do the same for the first frame of the anim but don't see an option. I was hoping that “hold the first frame” in the parameters would mean that it would hold it for x amount of frames but it doesn't. Does anyone know how this can be done?
Thanks for the help!
You can also use a timeshift node, and use an expression such as clamp() to hold first and last frames:
clamp($F,101,150) this will hold the first frame of 101 and last frame of 150 indefinably.
Ian Farnsworth
Thanks so much. Timeshift is perfect.
