Blowtorch in Pyro ?
   8522   10   1
Hi everyone,
I wanted to make a blowtorch in Pyro, like a reactor flame (here my goal was to make it looks like the little Iron Man reactor). I'm not satisfied with the result, I mean it works, it's a bit more “artistic”, but I was not able to find how to make a beautiful burst flame, like a candle flame but with a higher velocity I think.
So my question is, how can I achieve this kind of look ?
Pyro is pretty addicting but it's sometimes complicated to get the shape I want !
(it's an old version, now the fire is colliding and “sliding” on the ground)
Thanks !
pyro copy.png (381.3 KB)
https://vimeo.com/obreadytom [vimeo.com]
Hi there.
Do you have a video, or at least, an image of your reference?
The iron man reactor thing is a bit loose…
Javier Meroño
FX TD.
Hey,
Here at 18s for example :
https://vimeo.com/90277984 [vimeo.com]
And this is the animation :
https://vimeo.com/94225841 [vimeo.com]
Nobody ?
You really don't need to use a fluid sim for a blow torch effect. You can generate the shape in sops and create a volume from that, using the pyro shader for the render.
Hey Icarus,
Thanks for your answer. I thought about it actually, I wasn't sure that it was a good solution. But you're right, I should try it…
But it can't be made with pyro ?
It's sometimes hard to get the look you want with pyro, and only for learning purposes it would be great if someone can explain it to me !
Can pyro not just do a steady emit? it's always flickering and pulsing. i feel like that should be controllable.
https://www.orbolt.com/asset/SideFX::pyrojetexhaust [orbolt.com] ?
Ian Farnsworth
I cant really download these things for work. is there a parameter or combination of parameters that controls the pulsing in the fire? i suspect it is heat and temperature. i ahve all the noise turned off of them and yet they still have extremely fast flicker.
That's too bad, because that otl is a simple easy to use pyro setup.
I'd say start with a high velocity source, turn off noise in the source – so it has little to no variations in the denstiy / temperature /fuel. Then turn off the turbulence and shredding and disturbance in the pyro solver. The shape of the source and also make a big difference as well.
Ian Farnsworth
