I have a mesh going into a Wireframe sop (see attached .hip). Since upgrading from H12.5 to H13, it is no longer rendering as expected. Do you happen to have a clue why?
It almost looks like the tubes are inside out. The Wireframe's “Wire Radius” is set to 0.0002. When I increase it by a factor of 10, the expected results start to creep back in. Anything greater than 0.02 looks as you would expect. It's not really feasible to scale my entire scene up for this issue.
Swapping the Wireframe sop for the PolyWire sop fixes it, but by default, generates much too heavy of a result.
Any ideas? Thanks in advance.
-Greg
issue rendering Wireframe sop
3350 5 1-
- grhart
- 21 posts
- AdamT
- 184 posts
- grhart
- 21 posts
- Skybar
- 166 posts
Works fine when rendering with Micropoly. When rendering with PBR/Raytrace I'm getting the same as you. Note that if you have “preview” checked in Render View, it will raytrace regardless of your Mantra ROP setting.
edit: And if you pop down a Convert SOP afterwards to actually make it into polygons, it works fine in PBR as well.
- grhart
- 21 posts
- AdamT
- 184 posts
Ah, I did try a mantra render but turned off Preview (habit) so it didn't screw up.
I never realised they gave different results under Micropoly & Raytrace… nice lesson learned.
Edit:
Ok so I went back to H12.5 and sure enough it's running Raytrace in Preview - and the results are indeed different. Raytrace in H12.5 renders them the same as Micropoly.
Bug it?
Edit:
Bug it?
