Hello everyone. As expressed in the title, that's my problem. I'm kind of new to Houdini. I have my color input connected to a fit node, then converted to float value, and when I connect that node to my bind export, the attribute does not appear in the spreadsheet. I don't know if it is just a silly UI thing that I did not check, or if the attribute is not being exported at all. Just so you know, I'm following some tutorial about a melting angel, which I heard was a good place to start, along with the side fx ones; maybe that helps.
Thanks in advance, and sorry for my crappy english, if so.
Bind Exported Attribute Not Showing In Geometry Spreadsheet
3214 2 2-
- nachogsanchez
- 6 posts
- goldleaf
- 4300 posts
- nachogsanchez
- 6 posts
goldleaf
Sometimes panels get ‘pinned’ (see the screenshot), so they don't update to the current node. Or maybe you're looking at the wrong class of attribute in the spreadsheet? I assume you're in a Point VOP?
If you're able to share a hip file, that's always helpful.
That was it, thanks so much for the quick answer!
Cheers.
