pin constraint and Bullet - Stop simulation
5601
18
1
Grzesiek B
Oct. 7, 2016 7:33 a.m.
Hi, I have so weird issue with constraints two objects and bullet solver. After 52 frames my simulation just stop. I have almost defaults settings. I have only animation (noise) in Constrained Location - Y.
Edited by Grzesiek B - Oct. 7, 2016 07:34:44
HIPsim_constrain.hip (306.5 KB)
matthias_k
Oct. 7, 2016 10:36 a.m.
Uuups… it's the sleeping time… increase it or set it to 0
Edited by matthias_k - Oct. 7, 2016 11:00:58
Grzesiek B
Oct. 7, 2016 11:05 a.m.
I deleted all expressions and Still the same problem. But, when I used RBD Solver works fine - in this example. But RBD Solver some time has I problem with collisions. Some times H. is frustrating
Grzesiek B
Oct. 7, 2016 11:08 a.m.
aha… OK
…. where?
matthias_k
Oct. 7, 2016 11:13 a.m.
Please have a look at the image above, I've corrected my prev. post. In the “rigidbodysolver1” Tab -> “Bullet” -> “Sleeping Time”
Edited by matthias_k - Oct. 7, 2016 11:19:19
Grzesiek B
Oct. 7, 2016 11:20 a.m.
I dont have this options. A checked all nodes inside this solver and I couldn't found
Edited by Grzesiek B - Oct. 7, 2016 11:21:32
Grzesiek B
Oct. 7, 2016 11:27 a.m.
ok….
I don't know why my bullet hasn't this option
matthias_k
Oct. 7, 2016 11:30 a.m.
sek, searching….
matthias_k
Oct. 7, 2016 11:34 a.m.
Windows -> Operator Type Manager -> Configuration Tab -> “Display Menu of All Definitions” Then You should have the Option.
Edited by matthias_k - Oct. 7, 2016 11:34:34
matthias_k
Oct. 7, 2016 11:43 a.m.
Alternative do this one
Grzesiek B
Oct. 7, 2016 11:53 a.m.
hmmmm….. I don't have this option
Edited by Grzesiek B - Oct. 7, 2016 11:54:26
matthias_k
Oct. 7, 2016 11:55 a.m.
which version of houdini do you have?
Grzesiek B
Oct. 7, 2016 noon
Houdini 15.5.565 …maybe I should reinstall my H.
Edited by Grzesiek B - Oct. 7, 2016 12:00:31
matthias_k
Oct. 7, 2016 12:01 p.m.
Ahhh, open the “Bullet” folder… or search in the “Filter” field below for “Sleeping”
matthias_k
Oct. 7, 2016 12:02 p.m.
I Have a 15.5.607
Grzesiek B
Oct. 7, 2016 12:03 p.m.
matthias_k Ahhh, open the “Bullet” folder… or search in the “Filter” field below for “Sleeping”I did. And I don't have
Ok thax for help I reinstall and I will see.
matthias_k
Oct. 7, 2016 12:22 p.m.
this is a fixed version, maybe then you have the params
HIPsim_constrain-0-sleeping-time.hip (303.8 KB)
matthias_k
Oct. 7, 2016 12:52 p.m.
Alternative if you do not find the parameter at all…
Grzesiek B
Oct. 7, 2016 4:10 p.m.
….yes. unbelievable. really thanks for help
