documentation for toolutils
   9033   7   4
Looking at previous threads, it appears that the best way to get documentation about toolutils module is to find the corresponding py file in this folder
C:\Program Files\Side Effects Software\Houdini XX.X.XXX\python26\lib
However, I cannot seem to find the actual module in there even after string searches inside of the modules in the folder and subfolder. Which file should I be looking for?
-G
You need to be looking in the Python folders located in $HFS/houdini.
For example, C:\Program Files\Side Effects Software\Houdini 12.0.642\houdini\python2.6libs
ah perfect! thank you!
-G
for future visitors looking for toolutils documentation - you can read it here:
https://jtomori.github.io/houdini_additional_python_docs/toolutils.html
[jtomori.github.io]
And you can also find other modules here:
[jtomori.github.io]
Best,
Juraj
*Cue Hallelujah chorus*
Hello, why is the module toolutils separated from hou? And why the documentation is not on sidefx? Is it a module created by other people? I'm confused
Can I do the following with just the hou module, without toolutils?
import toolutils
viewer = toolutils.sceneViewer()
viewer.displayRadialMenu("myCustomRadialMenu")
I'm not able to get an instance of the sceneViewer class just with the hou module
any help welcome!
cheers
Edited by Andr - Feb. 3, 2019 09:29:54
Andr
import toolutils
viewer.displayRadialMenu(“myCustomRadialMenu”)
viewer = hou.ui.paneTabOfType(hou.paneTabType.SceneViewer)
https://gumroad.com/alexeyvanzhula [gumroad.com]
thanks a lot Vux!
