Asset does not load on other machines
   7300   4   1
When I create an asset from Houdini Indie, I can load and use that asset in 3ds max as expected. Everything works fine.
However, on another computer, running Houdini Engine Indie, when I try to load the asset, I get this window:
That window is always empty, and I am unable to load or use the asset.
Edited by eikonoklastes - May 12, 2019 02:57:37
To narrow down the problem I have a couple questions:
Does the HDA have a .hda or a .hdalc extension?
That dialog appears when an HDA contains more than 1 asset. Is it correct that the HDA you're trying to use has multiple assets?
Hi again! First up, I don't know what happened to the title of this thread and why it just said “Asset”. I've updated it now to be more descriptive.
The asset itself has an .hdalc extension. I've attached it here now.
This issue isn't restricted to this particular asset. Any asset I use produces the same result.
Edited by eikonoklastes - May 12, 2019 03:03:10
Ceiling_Pattern_Generator.hdalc (11.8 KB)
Just to double check: when you go to the Session Configuration tab, is there an active session running?
Hello. Yes, there is an active session. I just tried using an in-built asset and I get the same result.
Capture 1.PNG (27.3 KB)
Capture 2.PNG (14.1 KB)
