I'm hitting a wall with this problem that I have not been able to circumvent with my HDA losing parameters from one iteration to the other.
The setup is as follow :
- I have a Multiparm Block controlling a for loop in the HDA to retrieve the parameters of the interface (iteration = multiparm #). All is working fine with most of the nodes I have. But a few of them are getting out of control (it seems to be the ones using VOPs actually, and/or ordered menus).
- To access the parameters from the interface, I use a Spare Input on the nodes (the metadata node of the for loop) so I can find which specific parameter I have to query.
You can see in this first screenshot the parameters I setup :
Once I Apply the change, and Edit the HDA again, some of the parameters are gone as you can see here :
And obviously, this is generating errors now that the parameters are not there anymore. The 2 nodes that are “losing” those parameters are AttributeNoise and Mountain, all the other ones are behaving as expected.
So I wanted to know if there is something wrong I'm doing or it looks more like a bug ?
Thanks a lot,
Julien
