Hello Houdini Community,
First post here, I have appreciated all the help I have gotten from this forum while learning Houdini. I am easing my way into VEX and am running into a wall with this seemingly simple task. I am using curves to create Sweeps, I then use a Carve to animate the sweeps based on frame range. My trouble is that I would like to have each Carve animate as follows:
1. Each Carve “Second V” pick a random frame between 1 - 40 to start
2. “Second V” Animate from 0 - 1 over a period of time (Random time length from 10 - 50 frames)
3. Have First V follow behind
In the example attached I have set up a partial scene. Ideally, this method above would be applied to thousands of strokes with varying lengths! Any VEX help would helpful - really trying to get through this learning curve!
-Patrick
Offsetting Animation in VEX
3645 1 1-
- pscruggsjr
- Enivob
- 2659 posts
If you think of your lines as hair, you can use one of the groom nodes to randomly set the length of each line. This will give you a different travel time for each carve.
Try using the GuideProcess (set length) node.
Edited by Enivob - Nov. 2, 2020 09:50:05
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
