Hi all! I am new to houdini and started to watch this video by Robert Magee: https://vimeo.com/739705211 [vimeo.com]
On 11:11 there is an expression (i attached screenshot also).
Can someone please to explain how this expression called in trigonometry and math. Wanna know more about it (how calculate rotation and other staff)
I thought it arc lenght, but it seems like not.
Thanks in advance!
Houdini expression $Pi question in Learning Materials
2322 4 2-
- BFunnyKatrine
- 7 posts
- Tanto
- 550 posts
In the expression, the (2*$PI*1.1) part probably calculates the circumference [en.wikipedia.org] of the ball. The circumference formula is 2πr, where r is the radius, so we can assume the ball has a radius of 1.1.
When the ball moves in x (the ch("../../soccerball_ctrl/tx") part of the formula links to its x translate value) the length of its circumference, the two values cancel each other in the formula, and you're left with -360 as a rotate x value, a full rotation.
So basically the expression makes it appear as if the ball is rolling when you're translating it in the x axis, by linking its x rotation to its x translation in the correct ratio.
Edited by Tanto - Oct. 31, 2023 16:41:02
- BFunnyKatrine
- 7 posts
Tanto
In the expression, the (2*$PI*1.1) part probably calculates the circumference of the ball. The circumference formula is 2πr, where r is the radius, so we can assume the ball has a radius of 1.1.
Thank you for your answer! But we contained expression in transform node using Rotate Z axis, while using translate X.
Can I somehow see how riatet Z axis of transform node is changing while you move translate x axis? I tried using geometry spreadsheet,but not helpful.
Edited by BFunnyKatrine - Nov. 1, 2023 12:04:08
- CYTE
- 805 posts
- BFunnyKatrine
- 7 posts
Now I can see what degree value is changing by the expression.
