BUTTON STRIP : how to query their values in hscript?
   3518   5   1
if you query the button's values, it appears to only return a single int, and that int is the added results of all the pressed buttons.
for example:
none pressed = 0
button1 = 1
button2 = 2
button3 = 4
button4 = 8
button1 + button4 = 9
button2 + button3 + button4 = 14
i can't imagine putting in a gazillion if statements for all the possible numbers that could indicate if button2 was currently pressed, so i wonder if i'm missing something about this.
the query is this:
ch("../null1/Masks")
i've tried other ways of querying the value in an array or dict manner but all failed...
but no way can a multiple choice button be this difficult to use....!?
thanks in advance!
-seneca
multichoice buttonstrips or iconstrips are represented as bitfield
use bittest() to check which bit is on
it will return 1 if the bit in question is on and 0 if off (meaning if the button is on or off)
to check if first button (0) is on do:
bittest(ch("../null1/Masks"), 0)
second button (1):
bittest(ch("../null1/Masks"), 1)
third button (2):
bittest(ch("../null1/Masks"), 2)
fourth button (3):
bittest(ch("../null1/Masks"), 3)
fifth button (4):
bittest(ch("../null1/Masks"), 4)
CG Supervisor
Framestore, NY
thank you so much! i knew there had to be a sane way to query their values. i wish this stuff was easier to find in the docs.
hmm. how would you use this in a gui's HIDE WHEN field ?
this doesn't appear to work :
{ bittest(cow,0) == 1 }
indigosm
5 years later and i ran into the same issue. based on my readings, It seems like the field just doesn't support bittest()function.I solved it by creating one with a proxy parameter. hope it helps! (and anyone who came across this in the future)
here's a gif on how I did it:
https://i.imgur.com/Ic0j68Q.gif [i.imgur.com]
Edited by Irene_Howard - April 16, 2025 19:36:19
Irene_Howard
awesome! now if only i could remember what tool i was using a button strip in..... hahaha.
