Hi everyone! I have been using OSM for procedural road and city block generation. But recently I think something happend with either OSM maps or the mapbox labs tool in Houdini and while it downloads maps - its not processing any/breaks on import. I think there is potentially a problem with the Python script, but I am not proficient with scripting enough to fix that. Its usually giving out "file not found" with an occasional not breaking, but outputting 0 geo.
So I was wondering if anyone has fixes/alternatives for OSM? I am looking for something that hopefully can give out height maps for terraign, curves for roads and maybe some sort of guide geometry for building placement. I have conseidered Laserscans - but the free material is limited, and its mostly good for terrain only.
OSM & Mapbox fixes/alternatives
1226 5 1-
- GalinaB
- 3 posts
- Danicka
- 8 posts
- GalinaB
- 3 posts
- Danicka
- 8 posts
- stinzen
- 44 posts
I've been working on this topic as well. There is a video from Entegma called "Houdini Game Tools Assembling a 3D Scan Of The Earth", going through another method for aligning osm with height.
Their way of downloading heightmaps didn't work for me so I ended up getting height data from QGIS and the plugin OpenTopology and other sources. I then used osmosis to clip the osm in the same region and the Entegma method of aligning it in houdini. I thought about writing a blog post to go though the steps as it's a bit complicated
Otherwise you might want to look into the "Mapbox on steroids" node that someone made, haven't tested it in a while so don't know if it has the same problems as the original.
Edited by stinzen - Feb. 24, 2026 04:53:30
- GalinaB
- 3 posts
Hi! Thank you for the tip on the Entegma video - I will be sure to check it out. Sadly the mapbox on steroids is experiencing the exact same problems. As far as I understand there is a problem with the code downloading data and since both mapboxes dowload similarly - they fail at it similarly? Not sure though.
Would love to see the post describing the QGIS/OpenTypology process if you end up making it! It sounds very interesing.
