Hi everyone,
I have a question related to the node Lop Import Camera in OBJ. I've been doing some VEX dependant of camera view and positions, and I started working with normal OBJ cameras, but then I tried with USD cameras importing them to OBJ with the lop import camera nodes, and found that the cook times raised a lot.
I saw that the lop import camera uses python to read the values from the usd camera, so I tried removing them and got times down again.
Just for some context, I'm doing a multicamera prune in sops using the lop import camera to read this cameras in obj. Mainly using toNDC VEX function to read positions on each frame and then work with that data to prune points.
Is there a better way to do this than lop import camera + toNDC? Right now the bottleneck is the python scripts on the camera parms, so any improvements on that would be awesome!
As always thanks guys for reading me!
Lop Import Camera performance issues.
1250 1 1-
- RodrigoMartin
- 27 posts
- RodrigoMartin
- 27 posts
replying to myself in case someone in the future find this useful:
I've found a workaround to the python bottleneck using VEX, reading with usd_attrib the values from the camera that I need to read (horizontal aperture, focal length and vertical aperture) storing this on points (1 point per camera) and then it's easy to read this values from the rest of the network, (including the lop import camera using a multiparm with the point values in a spare node)
I got a reduction in time from 15 seconds to 1.5 it's still far from what you get using legacy cameras in OBJ (around 0.45 seconds) but it's much better than using the default lop import camera python way.
