Python - set callback for dynamically created parms
   1258   2   0
Hey, I'm kida stuck on how to do this - in short, i've got a shelf tool that adds an ordered menu UI to selected nodes. And I need a callback when the selection changes in this menu. Easy with static UI, but I couldn't figure it out with dynamically created one. This is a simplified code:
import hou
node = hou.selectedNodes()[0]
menu_items = ["aaa", "bbb", "ccc", ]
if node.parm("select_texture_node") is None:
    ordered_menu_parm = hou.MenuParmTemplate(
        name="select_texture_node",
        label="Select Texture Node",
        menu_items=menu_items,
        script_callback=hou.MenuParmTemplate.setScriptCallback(node.parm("select_texture_node"), print('pressed'))
    new_parm_group = node.parmTemplateGroup()
    new_parm_group.addParmTemplate(ordered_menu_parm)
    node.setParmTemplateGroup(new_parm_group)
This line is obviously a wrong syntax that crashes Houdini:
Not sure how it should look to make it work. Docs not helping. ChatGPT was giving me BS on this one. Any hints?
thanks, D.
try this
        script_callback="print('pressed')",
        script_callback_language=hou.scriptLanguage.Python
or alternatively if you want to use your mentioned setScriptCallback() method you do it after you instanciatee the MenuParmTemplate
    ordered_menu_parm.setScriptCallback( "print('pressed')" )
    ordered_menu_parm.setScriptCallbackLanguage( hou.scriptLanguage.Python )
Edited by tamte - April 8, 2025 22:01:44
Thanks Tomas, the first and the most obvious solution works. That was actually the first thing I tried and it was giving me error. I didn't realize the default script language is Hscript so it was needed to specifically set it to Python. Stupid but easy
Thanks.
