I'm sure there's a way to do this but the math is eluding me right now. I'd like to bend polylines in Y with a ramp, to simulate drooping from gravity (without running a sim) but I need to preserve their length.
float u = vertexcurveparam(0, i@vtxnum);
float b = chramp('bend', u);
float mask = b * chf('scale');
v@P.y -= mask;
Ideas?
Bend polyline with VEX expression preserving length
1581 3 0-
- AndyW
- 343 posts
- AndyW
- 343 posts
Here I can kind of fake it by multiplying the bend by the dot product of the direction of the lines and an up vector (getting the direction angle as @dir upstream) this keeps downward facing lines from stretching
float a = primintrinsic(0, 'measuredperimeter', i@primnum);
float r = fit01(rand(@primnum), 0.5, 1.5);
vector up = {0, 1, 0};
float d = fit01(dot(up, v@dir), 1, 0);
float mask = b * chf('scale') * a * a * d;
v@P.y -= mask;
v@P.y -= mask;
- cncverkstad
- 177 posts
float droop_amount = chf("droop_amount"); float tension = chf("tension"); int use_ramp = chi("use_ramp"); float axis_blend = chf("axis_blend"); int preserve_length = chi("preserve_length"); int prims[] = pointprims(0, @ptnum); if (len(prims) == 0) return; int prim = prims[0]; int vtx = vertexindex(0, prim, @ptnum); int count = primvertexcount(0, prim); float t = float(vtx) / max(count - 1, 1); if (use_ramp) { t = chramp("droop_ramp", t); } vector axis_dir = normalize(lerp({1,0,0}, {0,0,1}, axis_blend)); float arch = pow(t * (1.0 - t), tension); float dy = -arch * droop_amount; @P.y += dy; /* if (preserve_length) { float stretch = 1.0 + abs(dy) * 0.05; vector center = getbbox_center(0); vector dir = normalize(@P - center); @P = center + dir * length(@P - center) * stretch; } */
Conservation of Momentum
- AndyW
- 343 posts
