Integrating ComfyUI AI-generated concepts into Houdini
   6254   2   2
Hi everyone,
I’m currently building a pipeline where I generate concept images (vehicles, terrain, etc.) using ComfyUI (Stable Diffusion) and then feed them into Houdini for further processing – either as reference or for semi-automated geometry creation (through ML-enhanced Top Networks, depth maps, segmentation, etc.).
The idea is to have a semi-automatic flow:
Input prompt in ComfyUI → image generated
Houdini picks latest image from directory (using COP2 or TOPs)
(Later) Use ML to extract depth / structure → create procedural model or layout
Final output goes to Unreal Engine as asset/environment
🔧 I’m still in the early phase, so I’m experimenting with:
integrating ONNX inference directly inside Houdini
controlling generation from within Houdini (via Python)
proceduralizing based on 2D-to-3D logic or tagged structure
I'm wondering:
Has anyone built something similar (AI > Houdini > UE pipeline)?
What would you recommend for handling image-driven procedural generation?
Any tips for integrating ComfyUI output dynamically into COP2 / TOPs networks?
Here’s a screenshot of the current system in action (ComfyUI + Houdini preview):
Thanks a lot – I’d love to share more as this progresses!
Pavel
https://www.novusion.eu/ [www.novusion.eu] | https://www.artstation.com/infinitex/ [www.artstation.com]
Edited by Pavel Dostal - June 10, 2025 02:13:04
interresting post!!
I did some HDA to request ChatGPT or Gemini but not ComFyui..
If you want to share more I'm in
Wow factor
Pavel Dostal
Hi everyone,
I'm wondering:
Pavel
Hi Pavel!!
That's super cool, I don't know if you saw this already but I have a similar project and open sourced it recently.
Let me know your thoughts
https://youtu.be/KB7gsxHXVFM [youtu.be]
https://github.com/CapybaraCrowporation/houdini-comfyui-bridge [github.com]
Rafa
