Coordsys rest projections
   765   2   0
What's the workflow for using rest for sticky projections on deforming/moving geo in Karma?
Struggling to fit the mantra paradigm into the coordsys workflow when the mtlxposition node only gives you position - not rest position.
rest position would be loaded with a geompropvalue node if the geometry has such an attribute. For transforming geometry, object space is a sort of 'rest' position, and the position node can be used with the space set to "object".
I'm currently using the position node to set tex:ndc - can I also transform to object space somehow?
