Render stopping
   791   1   1
Hi, I’m running into repeated crashes with Karma in Houdini 20.5.332.
My scene is very simple: just a car simulated in RBD and a smoke sim behind it with a bit under 100M voxels.
I’m on an i9-13900K, RTX 4080 (16GB VRAM), 64GB RAM, Windows 11.
The issue is that after less than ten frames Karma consistently crashes with a segmentation fault. The crash logs don’t always point to the same place: sometimes it’s during volume evaluation (BRAY_VolumeSpan), sometimes in shader evaluation (MaterialX/VEX), and sometimes during EXR image output (IMG_FileEXR, OpenEXROutputFile).
It doesn’t seem tied to a single asset since the crash happens in different parts of the render pipeline depending on the run. I can provide the crash reports if needed.
Does this sound like something suspicious on my setup, or is it just bad luck hitting known Karma instabilities?
EDIT: I added a 4th crash dump that happened after my post. é
Edited by tq_stn - Aug. 22, 2025 06:22:20
crash_001.pdf (436.6 KB)
crash_002.pdf (279.9 KB)
crash_003.pdf (298.7 KB)
crash_004.pdf (270.2 KB)
The log seems to show Arnold's HTOA plugin crashing. Uninstall that software and try rending with Karma again.
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
