How to instal OpenFX plugins?
3511 5 3-
- parrtizan
- 4 posts
Hi, does anyone have any successful experience installing OpenFX plugins in Copernicus?
I tried installing several different releases of OpenFX, but I had problems with compilation, or Houdini simply did not respond when I added plugins to the OFX folder.
I am most interested in this plugin library: https://github.com/NatronGitHub/openfx-misc [github.com] Maybe anyone managed to install it?
- parrtizan
- 4 posts
Okay, I managed to install the Sapphire plugins from their launcher. During installation, all libraries are immediately placed in C/Program Files/Common/OFX. There are a bunch of cool effects that work in Copernicus.
Now I'm trying to figure out how to connect third-party open source libraries.
Edited by parrtizan - Aug. 23, 2025 11:40:12
- JustinCrapse
- 11 posts
I installed the demo for Sapphire. The plugin shows up in C:\Program Files\Common Files\OFX\Plugins, but nothing is showing up in Houdini Copernicus.
My system environment variables:
OFX_PLUGIN_PATH = "C:\Program Files\Common Files\OFX\Plugins"
HOUDINI_DISABLE_OPENFX_DEFAULT_PATH = 0
Am I missing something?
EDIT: So I fired up Houdini 20.5 and it worked. Still does not work in Houdini 21.
Edited by JustinCrapse - Oct. 22, 2025 21:16:09
- abigailb
- 8 posts
JustinCrapse
that should be enough to get Houdini to look for OpenFX plugins. can you see if there are any errors on the console?
- JustinCrapse
- 11 posts
- ajz3d
- 654 posts
Regarding
Then I moved
The only envar related to OFX that I have set, is OFX_PLUGIN_PATH, which points to
I haven't tried it on H21 yet.
openfx-misc, on GNU/Linux and H20.5 I installed it by following installation guidelines provided in the README.mdfile:git clone https://github.com/NatronGitHub/openfx-misc.git cd openfx-misc git submodule update -i -r git checkout Natron-2.5.0 make CONFIG=release BITS=64 CXXFLAGS_ADD=-fopenmp LDFLAGS_ADD=-fopenmp
Then I moved
Misc/Linux-64-release/Misc.ofx.bundleto my OFX directory, under Pluginssubdir:sudo mv ./Misc/Linux-64-release/Misc.ofx.bundle /mnt/res/ofx/Plugins/
/mnt/res/ofx.I haven't tried it on H21 yet.
Edited by ajz3d - Oct. 24, 2025 14:40:15
