Anyone else working on fedora and have Houdini 21 working fine or run into licensing issues?
I have it set to use sidefx server for licensing but I do see ton of SELinux notifications and problems.. maybe something messed up in there?
Fedora 42 and H21 licence issues
1975 4 2-
- Mirko Jankovic
- 292 posts
- terry_williams
- 59 posts
- Mirko Jankovic
- 292 posts
- johnlilpy
- 52 posts
- Luca Scheller
- 2 posts
Hey,
I've recently also run into this issue and solved it by running the following steps:
This installs the necessary selinux policies.
You might also need to check in the license manager if it is still preferring the local license server (over the sidefx server).
Luca
## Install SeLinux Policies # sesinetd sudo systemctl start sesinetd.service sudo ausearch -c 'sesinetd' --raw | audit2allow -M sesinetd_local sudo semodule -i sesinetd_local.pp # hserver sudo systemctl start hserver.service sudo ausearch -c 'hserver' --raw | audit2allow -M hserver_local sudo semodule -i hserver_local.pp ## Reboot (or try running) sudo systemctl daemon-reload sudo systemctl restart sesinetd.service sudo systemctl restart hserver.service
Luca
Edited by Luca Scheller - Sept. 4, 2025 23:49:04
