Failed to install hserver. Process exited with code -1073741
   1221   2   0
Trying to install houdini launcher ,
it was working before I've tried to update the launcher , now It won't work anymore.
The log file doesn't exist
Output folder: C:\Program Files\Side Effects Software\Launcher Extract: Uninstall Houdini Launcher.exe Extracting files... Installing Microsoft C Run-Time Libraries (this could take several minutes) Installing Houdini Server... Failed to install hserver. Process exited with code -1073741502. See log file "C:\Program Files\Side Effects Software\Launcher\logs\install-hserver.log" for details.
Thank you
Johnny
From my test this is related to my CPU being old , and houdini 20.5 latest only acepts newer CPUs
https://www.sidefx.com/forum/topic/100529/ [www.sidefx.com]
just running into the same problem here. My CPU is old but I'd happily work on an older version. If I can't get past the launcher then I guess I need to look at using the old installer.
