Hi everyone,
I’m a Houdini enthusiast and have been exploring the new Shadow Catcher workflow in Karma (since Houdini 21). First of all, I appreciate the improvements; it seems largely based on the old background plate workflow, giving holdout geometry a matte material that allows shadows to appear while maintaining visibility in the viewport.
However, I’ve run into a problem with certain layered rendering workflows. Here’s the setup:
* I have a scene with a ground environment, debris, and an explosion.
* The scene requires layered rendering so that each element can be rendered separately, while still allowing other objects to contribute shadows for compositing.
My rendering workflow is as follows:
1. **Ground pass:** Render the clean ground only, using a prune node to disable other objects.
2. **Debris pass:** Disable the explosion via prune, set the ground as a holdout matte, and output the required AOVs: `beauty`, `holdout_shadow`, `holdout_reflect`, etc.
3. **Explosion pass:** Set both ground and debris as holdout matte, then output AOVs: `beauty`, `holdout_shadow`, `holdout_reflect`, etc.
Because volume rendering is extremely time-consuming, I only render the explosion once. This workflow allows me to get the beauty of each element and the corresponding `holdout_shadow` / `holdout_reflect` AOVs for compositing.
**The problem:**
* When the holdout is set to **Matte**, the `holdout_shadow` AOV **includes shadows cast by the holdout geometry onto itself**, which is undesirable for compositing.
* If the holdout is set to **Background**, the `holdout_shadow` AOV **no longer includes the holdout’s shadows at all**, meaning the holdout geometry does not cast shadows onto any other object — which is a critical issue for compositing layered elements correctly.
In short, with the current implementation, it’s difficult (or impossible) to achieve a workflow where:
1. The holdout remains a matte for visibility and indirect contribution (reflections, indirect lighting).
2. `holdout_shadow` includes **only shadows from other objects**, excluding self-shadow from the holdout itself.
This limitation makes compositing layered renders in Karma challenging, especially for complex scenes with debris, explosions, and volumetrics.
I would greatly appreciate any insights, workarounds, or guidance from the community or SideFX engineers on how to handle this scenario efficiently in Karma.
Thanks in advance!
Holdout Shadow AOVs in Karma
860 1 2-
- AAA2294417692
- 1 posts
- Mirko Jankovic
- 290 posts
