Hi there,
I want to procedurally model dice, with the text or pips as actual geometry on the faces. In a loop, I generate the numbers based on iterations and try to set i@face to match the iteration number, but I can’t make it work. The manual method works, but it's well… manual.
So if somebody has a small hint, that would be great.
Kind regards,
Christian
Update:
I made it work by switching from the Attribute Wrangle to an Attribute Create that happily accepted the iteration attribute.
Assign iteration in a loop as attribute
559 2 1-
- Schmauch
- 23 posts
- tamte
- 9560 posts
your path in
is invalid to begin with, since the node holding the iteration metadata is called foreach_begin1
but even if it was valid, detail() VEX function expects geometry, so either input number, file path or op: string pointing to sop node
since you want to directly point to sop node you need to specify it as
but it may be just easier to connect foreach_begin1 to 2nd input of wrangle and do:
i@face = detail("../foreach_begin", "iteration", 0) + 1;
i@face = detail("op:../foreach_begin1", "iteration", 0) + 1;
i@face = detail(1, "iteration", 0) + 1;
Edited by tamte - Nov. 20, 2025 17:16:47
- Schmauch
- 23 posts
Thanks again for helping out.
