I created a MaterialX compound node as blabla.mtlx file. Now I want to use it in Houdini. In Maya I can simply use the MATERIALX_SEARCH_PATH env variable and I can use my node. In houdini the node is not visible at all. How can I use my own nodes in Houdini Solaris?
How to add a user defined MaterialX compound in Solaris?
579 3 1-
- haggi krey
- 58 posts
- LiBoNing
- 31 posts
I found this in Sidefx's doc. There's a tool to convert the materialx file into a hda.
https://www.sidefx.com/docs/houdini/solaris/kug/materials.html#custom [www.sidefx.com]
That .mtlx source file is then post-processed by two other tools:
$HHP/mtlx2karma.py - outputs the karmaNodeGraph.json file necessary for Karma to render these shaders correctly; this should be added to HOUDINI_PATH or user preferences directory
$HHP/mtlx2hda.py - produces the user-facing output HDA, should be added to any otls folder on HOUDINI_PATH or user preferences directory
MotionCOPs toolkit - pushing COPS into motion design and dynamic effects territory.
https://github.com/Boning1011/motion-cops [github.com]
- Hip-Freak
- 35 posts
- haggi krey
- 58 posts
