How to batch export curves into single DXF file
   498   1   0
I have a pretty simple setup. A file node to a polyslice. I am slicing the file into N curves (200 in this case, but could be many more). I need each curve to be saved out as a single curve DXF file (which I will use in a laser cutter to cut the shape).
If I try to just save the geo as is it will export all curves on camera viewport. I need a single curve on a specific axis (top down).
Can't figure out a way to do this - clearly I'm no expert as there must be an easy solution. Thanks for the help!
WhatsApp Image 2025-12-28 at 11.03.20 AM.jpeg (629.7 KB)
Were the slices created along the vertical axis? Also there seems to be 2 curves per slice, like a wall thickness, how do you plan to handle that?
if it were me, I'd sort the polygons based on the vertical axis (using a sort SOP); then use a blast with the frame number in the group field and "delete unselected" checked; set a rop geo outputh to use the frame number in the naming of the DXF and set the range to be from 0 to the number of curves (-1) you have in your scene.
Toronto - ON
