CROWD: AGENT EDIT: offsetting an animation randomly
   496   2   2
I've animated the head bone of the agents of a crowd with an Agent edit node, creating a simple keyframed animation.
Of course, they rotate the head at the same time.
I was wondering if, excluding the obvious way of grouping and using some agent edit nodes with various starting frame, there was a way to do it by using VEX or something else.
Thank you in advance.
M
Life, the Universe and Everything... about 3D on Vimeo [vimeo.com]
You can enable the "Use VEXpressions" toggle to vary the parameters per agent - the drop down menu has an example snippet for randomizing the rotation
cwhite
That is what I was looking for.
Thank you so much.
