Curl up - Box fold Rig - Help!
   687   2   1
Hi all,
I'm trying to achieve this rig in kine fx for future flexibility, but can't seem to figure it out. The idea is the geometry to curl up from lying flat to the resulting box shap.
I've attached a clean file as a base, if anyone could demonstrate a workflow that would be amazing.
Edited by bashorton - Feb. 3, 2026 10:07:25
Curl_up_rig_base.hipnc (390.1 KB)
Here is an example how to use Kinefx rig to unfold a box.....you should be able to apply this to your scene
with little effort.
Basic principle:
Break the box into parts, pack those parts and use capture pack geo to move each part
using a basic skeleton rig, then unpack if required.....ideal for rigging solid parts that are not
required to deform, like a robot arm for example.....use the rigpose node to animate the rig.
Hope this helps.
Box-Fold-Rig_Basic.hipnc (164.1 KB)
"Genius might be the ability to say a profound thing in a simple way." — Charles Bukowski
EZiniT
with little effort.
Basic principle:
Hope this helps.
That's great, really simple setup with maximum control. Thanks so much for taking the time!
