Karma Texture Baker (workflow for UDIM assets)
   549   3   1
Hi there,
How are we meant to use the Karma Texture Baker in Solaris with a UDIM asset?
Currently I have just a single mesh needing an AO baked out. It has 1001-1004 UDIMs
Am I missing something here? Based on the docs I should be seeing:
/Render/karmabake_1001/Products/product_1001_Oc
/Render/karmabake_1001/Products/product_1002_Oc
/Render/karmabake_1001/Products/product_1003_Oc
/Render/karmabake_1001/Products/product_1004_Oc
..from what I understand?
Rendering out I get the AO but only for 1001, even changing the default UDIM to 1002 it still renders 1001.
Any tips?
Edited by dnew - Feb. 3, 2026 12:04:13
Screenshot 2026-02-03 at 17.03.17.png (3.0 MB)
This seems to be a bug. Could you please share the hip file with us or better if you log a bug please. Thanks.
This seems to be a bug on the view port. If you use USD Render ROP node, you can set Render Settings to "/Render/*" to render all UDIMs.
Edited by ali_f - Feb. 18, 2026 13:48:31
So,
- To render UDIMs all at once set USD Render ROP > Render Settings to "/Render/*"
- If Render Settings is left empty it uses "Default UDIM" tile on Kamra Texture Baker node
- To change the view port to the desired tile, select Render Settings under the view port
Karma Perspective menu as in the attached image.
