VEX - Accessing/printing coordinates from point ID
   157   1   1
Hi all
In an Attribute Wrangle:
int p0 = addpoint(0, set(0,0,0));
int p1 = addpoint(0, set(1,0,0));
int p2 = addpoint(0, set(1,1,0));
vector pos = point(geoself(), "P", p2);
printf("Position of p2 is: %g\n", pos); // This prints Position of p2 is: {0,0,0} which is wrong
I would like to access the coordinates of p2 and print them out. I'm using:
but instead of printing {1,1,0} it prints {0,0,0} which is wrong.
How could I print or access the coordinates correctly?
Thanks in advance
you can't
addpoint(), setpointattrib() and many other functions that allow creating/writing data to new or non-current element are queued to be executed later as a single threaded operation
furthermore point() or other functions that query data currently query the input geometry even if geoself() is used, as currently geoself() just returns 0 which is the cached first input geo
so currently writing/reading the newly written values within a single wrangle is limited to current element only using @ binding
EDIT: or if you are running within Detail wrangle you can probably store the values in an array to keep track of them yourself
Edited by tamte - March 18, 2026 16:14:32
