Okay, I don't know how to script with python but figured I'd better try.
I have a simple rig with a switch sop that is controlling which LOD of geometry I wish to display.
The switch has a range of 0-2, with the default at 1. The 0 setting shows no geometry, just bones. However I've turned off the visibility of some of the bones, when I'm displaying the geometry.
What I'd like to do is set a callback script so that when I change the switch to 0 all the bone display flags are turned on.
So I'm thinking it will be something like,
if switch < 1, setDisplayFlag on “bones”, 0
I don't know the correct syntax.
Who can help me?
Conditional statement in callback with python
4305 2 2-
- probbins
- 1145 posts
- symek
- 1390 posts
but you want to put this callback script in HDA definition, right?
If so, this should be put to PythonModule script section of HDA:
def switchDisplay(self):
def childrenFlags(self, val, type='bone'):
for child in self.children():
if child.type().name() == type:
child.setDisplayFlag(val)
if self.parm('switch').eval() == 0: childrenFlags(self, 0, ‘bone’)
else: childrenFlags(self, 1, ‘bone’)
Then in callback field of your parameter called ‘switch’ (like integer):
hou.pwd().hdaModule().switchDisplay(hou.pwd())
This switches display flags Off and On for all bones in subnetwork.
I think something has changed in callback area in 9.1 but I'm not sure what.
hope this help,
sy.
EDIT:
fixed type().name() method
hope this help,
sy.
EDIT:
- probbins
- 1145 posts
