Group Sop "Transfer Selection to Pattern" gone.
12789 14 2-
- gotfroi
- 5 posts
- old school
- 9 posts
This is long gone from Houdini now. The change happened in H5.0.
It is replaced with the new modelling workflow. You need to use the “Transfer Selection” red arrow in the viewport pane's left hand side, mid way down.
Press it, select your geometry, then tap the RMB and you now have set the selection for the Group SOP.
As for the docs, I see your point. :?
I will submit the bug
- Mudvin
- 66 posts
Hmm….doesn't work for me….
This “red button” calls “reselect geometry for current operation”, nothing common with “transfer selection”. And there's no any other red button on the left toolbar of viewport
Anyway, when i RMB clicking on the “pattern” field in the group sop parameters, field becomes gray while i'm holding mouse button, and nothing happens then.
One time somehow i get these ranges, but i can't reproduce it.
.Anyway, when i RMB clicking on the “pattern” field in the group sop parameters, field becomes gray while i'm holding mouse button, and nothing happens then.
wbr, Mudvin
- edward
- 8126 posts
- Mudvin
- 66 posts
- edward
- 8126 posts
- Mudvin
- 66 posts
- edward
- 8126 posts
- Mudvin
- 66 posts
Well, i describe process myself:
1. empty scene
2. sphere sop -> group sop
3. moving mouse into viewport, pressing ‘s’(select mode), then ‘1’ - points.
4. press red button(as you described)
5. selecting few vertices
6. pressing RMB in viewport/group sop's ‘range’ field/everywhere alone/with ctrl/alt/shift. No luck. Any ideas?
1. empty scene
wbr, Mudvin
- edward
- 8126 posts
Ah, I see your problem now. You're mixing up the two different ways of working in Houdini in the viewport. You can choose two workflow methods:
1. Choose the operation (aka tool) and then select your geometry, or
2. Choose the geometry first and then choose your operation (aka tool).
Let's assume that you first put down a sphere. Change it's type to polygon for the sake of this example. Throughout this whole process, make sure you watch the blue prompts in the status bar at the bottom when your mouse is in the viewport. Reading them help.
In workflow 1, you now go into the viewport and hit Tab, type Group <enter>, select geometry and right-click (in the viewport).
In workflow 2, you hit ‘s’ to select your geometry. Now hit Tab > Group <enter>.
In either case now, you can choose different geometry via the reselect button that we've been talking about thus far to choose different geometry.
Have you done through the video tutorials on modelling? They're here:
http://www.vislab.usyd.edu.au/sidefx/houdini_video/by_topic/modeling/index.html [vislab.usyd.edu.au]
- edward
- 8126 posts
- Mudvin
- 66 posts
Yeah, got it. I've thought that i'm able to put current selection into a group node without pressing enter, ie with simply selection mode.
Hmm…..but anyway - is there some way to put current selection into a group sop, if i'm in it's editing mode? Just curious.
PS: Thanks, Edward. I'm new to Houdini, and some things are looks pretty strange for me.
wbr, Mudvin
- edward
- 8126 posts
- stevenong
- 1634 posts
Hi mudvin,
I believe the intro videos covers the different selection and modeling methods. Please go to the following link for the videos:
http://www.vislab.usyd.edu.au/sidefx/houdini_video/ [vislab.usyd.edu.au]
Definitely recommended for new users to Houdini.
Cheers!
steven
Cheers!
steven
- Mudvin
- 66 posts
