Hi Guys,
I've encountered a problem installing Houdini on Solaris 8. I'm trying to install an academic version of houdini on a sunblade 100 with a gfx graphics card. I have installed the opengl stuff and can now get a splash/welcome screen but then the application quits with no error
message.
After doing an ldd -d houdini I get the following error:
<snip>
libICE.so.6 => /usr/openwin/lib/sparcv9/libICE.so.6
libICE.so.6 (SUNWprivate) => (version not found)
/usr/platform/SUNW,Sun-Blade-100/lib/sparcv9/libc_psr.so.1
<snip>
I thought “ok.. i'll just install SUNWprivate” but I can't seem to get the pkg. If anyone can help, I'd really REALLY appreciate it.
Thanks dudes,
dan
Installing Houdini on Solaris 8
9013 3 1-
- daclark
- 4 posts
- pbowmar
- 7046 posts
Hi Dan,
What's the exact model of the graphics card? Also, are you able to get the command-line version of HOudini working? Instead of “houdini” type “hscript” (without the quotes of course) and see if you get any error messages. It could be a licensing problem. When you installed did you connect to the 'net and get the license automatically?
Peter B
Peter B
Peter Bowmar
____________
Peter Bowmar
____________
- jenosch
- 2 posts
I do have the same Problem under Solaris 9 (Blade 100 - PGX64 Graphic Board).
But my “ldd houdini” prints out no errors - so I have all necessary libraries.
The Command line tools do work - but they claim for the license (coludn't enter the license information because hkey won't start as well)
Please help us
Jens
Please help us
Jens
- jenosch
- 2 posts
I'have just installed an Sun Expert3dlite Frame Buffer.
With this device houdini does start up and i can begin working.
So I guess that the PGX64 doesn't have enough capabilities to display the houdini windows with opengl.
(It has only 8 MB of SGRAM and is only a 2d Accelerator).
Houdini is now running under:
Sun Blade 100
768 MB SDRAM
Expert3dlite
Solaris 9 (without any patches).
Jens
Sun Blade 100
768 MB SDRAM
Expert3dlite
Jens
