I give a particle a start velocity and a centripetal force then play animation.
but the trajectory is not a circle but a spiral curve. why?
Note that I don't want to use circle formula.
With force,how to make particle move uniform circularly?
3995 2 0-
- flyingc
- 160 posts
- tamte
- 9576 posts
- flyingc
- 160 posts
tamte
The initial force you applied is 4 in global X direction
then you are just adding incentric force, i cannot see the reason why it should be circular this way
Try using Orbit POP, it is made for this kind of motion
or you can make your own force with VOP POP
thank you .
i want to test how the force affect a particle's motion.
so I refer to the formula :f=mv^2/radius .
and set the start velocity and the centripetal force
