Orient Along Path
   7442   1   0
I'm able to animate along a path ok, but going to tweak the animation I'm coming to some problems.
The animation on the path speeds up where there are less points on the track and speeds up where there are less points. I'm assuming that the amount of points on the path has a direct result on the rate of position change. Is this correct? If so, is there a way to change this so that the rate of position change is independant of the # of points on the path?
tom
Hi Tom,
Use a Resample SOP on the path, that'll fix it right up.
Pter B
Peter Bowmar
____________
